up cycle a storm
up cycle a storm
well as i have two storms that kinda do the same job iv decided to,using a trendy word ,upcycle the yellow one. its now moved into the general use/touring roll but that brings problems :confused . soft front end. capacity to carry a weekends worth of clothes/drink and tank range.
well no need to thank me guys i have it cured.
soft front end sorted and better brakes to boot.
i have a renntec rack already fitted but for longer periods away i decided, how about a tow bar? yup thats works for.
and that dam small fuel tank and the range.. i thought of vfr tank but just dont like the shape of those so had to think outa the box on this one...sorted, i think it blends in fine with the rest of the bike and the new tank gives me a range of 1784 miles before the light comes on..
:eek2
Image..
these mods have been brought to you free of charge so feel free to copy them. :beer:
KermitLeFrog
Re: up cycle a storm
Post by KermitLeFrog »
"2001 A Space Odyssey". Just use the Force.
This pathetic post was brought to you by Mr Mixed Metaphor.
lmao.... i knew i shouldnt have taken those drugs today :lol: :lol:
Try to find yourself a Harris endurance tank :wink: If this is going to be for touring and genral runaround then maybe it's worth considering low level exhausts as then you have many options for panniers.
podman
Post by podman »
I like what you.ve done with that..
I have fitted the renntec top box to the rack , so thats clothing etc sorted, im heading off to Spa in June, which isnt that far but I was thinking of buying a fuel bladder, couple of options available, both expensive
https://www.mxstore.com.au/p/Desert-Fox ... UELCELLFOX
Or most likely a smaller can, which can be strapped or bolted to the bike, maybe the rack or subframe..
https://www.ebay.co.uk/itm/3L-Portable- ... SwDApagSdy
Here's some ideas - esp like the rear seat fuel tank that would give you more range
Robert Edison Fulton Jr. – One of the First Men to Motorcycle Solo Around the World
VTRDark wrote: Wed Mar 14, 2018 1:56 pm Try to find yourself a Harris endurance tank :wink: If this is going to be for touring and genral runaround then maybe it's worth considering low level exhausts as then you have many options for panniers.
well the harris tank is the holy grail :clap: tho it would go onto the blue bike if i ever won the lottery and found one... pipe wise i have a set of low levels here which i can swap on if im using soft panniers :thumbup:
