Bracing a standard swingarm
TaxiDriver
Post by TaxiDriver »
Back in the day you could take your Bandit s/arm to JMC @Kirby to have it braced.pretty good job,underslung
and kept the original chain adj
I can't find any trace of JMC now,does anyone know of a firm around the N/West that can do this work.
Re: Bracing a standard swingarm
Source a blade brace - hack it off and transplant onto the Storm up top. Have a search as it's been done a few times.
TaxiDriver
Wicky wrote: Thu Feb 08, 2018 8:27 pm Source a blade brace - hack it off and transplant onto the Storm up top. Have a search as it's been done a few times.
Cheers,just quickly,can I use original rear caliper mount using this mod?
No. You need a 929 or 954 blade caliper bracket, and weld a small oblong onto the arm it can slide on.
Or you could fabricate your own bracket and use an underslung caliper from a triumph or similar.
To see old pics you'll need to use Chrome with the photobucket-embed-fix hack installed
viewtopic.php?f=41&t=40234&p=439542
mik_str
Post by mik_str »
tony.mon wrote: Thu Feb 08, 2018 8:54 pm No. You need a 929 or 954 blade caliper bracket, and weld a small oblong onto the arm it can slide on.
you sure about that? I have never heard of anyone using one from a 929 or 954.
I have just such a modded arm and IIRC, simply use the bracket that mates with the donor arm (been a long time though)... Do a search here or on the superhawkforum, it`s well detailed and spelled-out....
Shauned71
Post by Shauned71 »
You want the swing arm and the caliper bracket from any early blade up to 1998. As well as cutting the brace off to fit to your storms swing arm you also want the caliper bracket guide from the blade swing arm... The guide on the Storm is a block that the bracket slides over... the blade has a channel that it's bracket slides into so you need to transfer that over too.
I have done this to my bike... I did all the cutting, lining up and marked where everything had to go and dropped the swing arm into a local fabricators to weld up for me.
TaxiDriver
Thanks for the reply's,I've decided to sack it off,you buggers are making me see opportunity's
all over the place.
I think I'll stick to strip/clean/ride for this season,after all I still haven't ridden one of these yet!!!! 8O :lol:
storms are like pringles..once you start you cant bloody stop :clap:
E.Marquez
Post by E.Marquez »
Shauned71 wrote: Thu Feb 08, 2018 10:17 pm You want the swing arm and the caliper bracket from any early blade up to 1998.
I do think thats the way most have done it...Never heard of using a 929 model caliper bracket...
I think 893 or 919 series Fireblade (1992- 1998 I think)
I went another route........and damn near killed myself :lol: Dont highly recommend that way, though its all worked out now.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
On mine I just used the bracket that came with the swingarm.
Like the others have said you need to swap the male stay for the female one from the donor arm but it is a pretty easy project. :thumbup:
8541Hawk wrote: Sat Feb 10, 2018 12:42 am On mine I just used the bracket that came with the swingarm.
Same here :thumbup:
Don't forget that your Storm hugger will no longer fit, you can get the combined hugger chain guard from a Blade and I think that an R1 version fits as well but couldn't tell you which years, check to see which model number fits other bikes on a site like Powerbronze.
