Rear disc bolts seized any ideas
TaxiDriver
Post by TaxiDriver »
As above really,2 of the rear disc bolts are solid,would heating them with a pencil torch help to free them?
Not sure if it is thread lock or corrosion,any help gladly welcomed....
cheekykev
Re: Rear disc bolts seized any ideas
Post by cheekykev »
Heat the casting up around the bolt area with a blow lamp.
Like what you do
Do what you like
Heat em sufficiently to soften any previously applied threadlock.
Varastorm
Post by Varastorm »
Shock them, put an Allen socket in the hole & tw@ it.
If you've not got one place an old 1/2 drive with a 13mm'ish socket or similar on an extension & tw@ it.
Just make sure you don't damage the Allen head on the bolt or miss & tw@ the disc :thumbup:
E.Marquez
Post by E.Marquez »
They come from the OEM thread locked , and any decent mechanic would thread lock replacements..
Heat the screw up to about 200 Deg C and it will soften the anaerobic thread lock, using an impact driver or gun and a high quality hex bit will help as well
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
TaxiDriver
:lol: :lol: :lol: :lol: :lol: I like it......
Cadbury64
Post by Cadbury64 »
I replaced the rear disc on my 28 year old ST1100, and the bolts were tough little buggers. Thankfully I have an electric impact gun, bought 2 years ago and only used 3 times, but each time has been a "hallelujah" moment. I'm sure if I just gave the disc bolts a big heave-ho with a long breaker bar, the allen heads would just round out. The impact gun shocks them loose with no damage (touches wood...).
TaxiDriver
Cadbury64 wrote: Thu Feb 01, 2018 2:51 am I replaced the rear disc on my 28 year old ST1100, and the bolts were tough little buggers. Thankfully I have an electric impact gun, bought 2 years ago and only used 3 times, but each time has been a "hallelujah" moment. I'm sure if I just gave the disc bolts a big heave-ho with a long breaker bar, the allen heads would just round out. The impact gun shocks them loose with no damage (touches wood...).
Can I borrow it!!!!!?
TaxiDriver
I!ve soaked em in +gas, I,ve tried tw@ting them and I,ve now got a pencil torch to heat em up at the weekend so here,s hoping.......
Varastorm
Post by Varastorm »
A heat gun is ideal also, you'd bee surprised how hot it'll get things :thumbup:
Cadbury64
Post by Cadbury64 »
TaxiDriver wrote: Thu Feb 01, 2018 4:58 pm
Sure, just pop around when you are free.
