Something wrong...
Something wrong...
...with this apart from the colour of course...
https://www.gumtree.com/p/honda-motorbi ... 1271524228
At first I thought it might of had a VFR tank fitted.
The pic from the other side doesnt seem to have the same cut out in the tank.
If you ask me that would be a little bit more than a split seam...
Re: Something wrong...
looks like a Yeti has taken a bite out of the tank to fit his air intakes
I was thinking that too, but the other side looks normal...
+ in the add he says the leak is on the L/H side.
Says it's black, too.
Odd sort of hue for black....
I'm not convinced. If you look carefully and zoom in it may very well be cut like the right hand side. I think it's a bit of an optical illusion and the angle of the camera and lighting as well as being a low res pic making it look normal.I was thinking that too, but the other side looks normal...
- alanfjones1411
Agree with you Carl.Thats could be the reason it leaks as well. If you know what I mean.
Doesn't look like its been cut on the kerbside er side like the obvious cut out on the offside. The owner saying it leaks from the 'left' side depends how he defines left and right either from sitting on it or looking at it from the front. Non standard stickers hint at respray.
Original ad pic enhanced
Normal kerbside aspect of bog standard tank
- alanfjones1411
Weird.Why would somebody do that,unless it was to fit a snorkel and have some kind of ram air ?
I'm not convinced either. The best thing to do would be for someone to ask for a better photo of the nearsideVTRDark wrote: ↑Sat Oct 21, 2017 1:13 amI'm not convinced. If you look carefully and zoom in it may very well be cut like the right hand side. I think it's a bit of an optical illusion and the angle of the camera and lighting as well as being a low res pic making it look normal.I was thinking that too, but the other side looks normal...
Looking at the bigger picture ha ha, why would someone go to all that trouble to only do one side,
Maybe because after making the first sodding great hole in the petrol tank to give it a race replica Moriwaki look they found it leaked fuelwhy would someone go to all that trouble to only do one side
PS Dafter things have been known - There was a while back a US chap called Shervin who modded his ZX10R and put 'mental' into emmental cheese...
http://blog.motorcycle.com/2010/05/27/m ... the-frame/
I nearly went to look at this bike when I was hunting for my VTR,phoned the bloke,but was put of by his attitude,very cagey,odd in fact.
took him of the 'to view list' found a better bike,and well happy now.oh and it's been for sale for at least six months....
You have a good point there Wicky, anything is possible I guess you've only got to look at your video linkWicky wrote: ↑Sat Oct 21, 2017 12:59 pmMaybe because after making the first sodding great hole in the petrol tank to give it a race replica Moriwaki look they found it leaked fuelwhy would someone go to all that trouble to only do one side
It would be nice to know for definitely though wouldn't it
Yeh it's defo looking one sided now So an attempt of ram air and screwing it up. Change the tank and be done with it. Use it as a bargaining chip to reduce the price.
i kinda want a tank like that. without the leak
