Brake disc opinions
- freeridenick
Brake disc opinions
Anyone got any thoughts on EBC vs Armstrong discs? I've got a set of each and I want to use the 'best' set with the Supercorsas and the others on the wets.
- StormyRob
Re: Brake disc opinions
I have heard from a few that EBC are not what they used to be and in that comparison people seem to rate the Armstrong highly.
Whichever set you do not usw...will they be for sale?
(I also did not give the above opinion based on my question!)
- freeridenick
Ha ha, thanks Rob. The plan is to use both unfortunately, one on each set of wheels to avoid having to swap discs as well. It's a right pain in the chuff.
- StormyRob
Fair enough mate. Always worth an ask
- freeridenick
Just try them, probably armstrong on the dry setup first.
You should be able to feel which works best.
