reservoir caps
Geeman
reservoir caps
Post by Geeman »
Hi everyone
Does anyone have any idea where I can get matching front and rear brake and clutch reservoir caps in alloy. tried ebay but look crap. Any suggestions will be greatfully received...cheers
Re: reservoir caps
oberon, or cheap ones from china on ebay. I theres also a firm called rizoma
Geeman
Re: reservoir caps
Post by Geeman »
Thank you...
Re: reservoir caps
They're a standard size across many other honda models so arent model specific.
Also suggest you get stainless screws for the brake side as they are less likely to jam in place.
And while you're ordering stainless, get some for the rear res as well, with that one the captive threaded inserts rotate too easily.
