Having been looking at the images in the Mori VTR article again I noticed that the intakes cover, or appear to cover, the three or four brass ducts on the top of the carbs. The std airbox has a cut out for these and the std intakes don't cover them up. At least I don't remember them doing.
So the questions are:
1) What are these ducts? Air jets?
2) Why do the Mori stacks cover them over? Is it because they are meant to be used in a pressurised airbox or because there are other mods needed to run these?
Mori velocity stacks question
- freeridenick
Re: Mori velocity stacks question
The mori don't cover them .
The base plates are shaped around them and the stacks screw into the base plate .
Oh and you don't need ram air to run them .
- freeridenick
Thanks. Got any pics?lloydie wrote:The mori don't cover them .
You could always have a go at making some These are DR Honda / HPower copies but the mounting is very similar to the Mori's so should give you a good idea. The biggest difference is that these are equal height whereas Moris are one one short, one long like standard stacks but more extreme and then obviously the curved top.
viewtopic.php?f=7&t=28350&hilit=velocity+stacks
that was an interesting read i have to say
- freeridenick
[quote="VTRDark"]You could always have a go at making some/quote]
Watch this space...
Watch this space...
