Yet more questions. Just been out for a run to test bike after numerous jobs. Much improved. The bloody forks though bottom out on the smallest speed bump and clunk- awful, cant wait to get them sorted.
Anyway when I pulled up and shut off engine I noticed the fan was going so had a look behind the radiators to check it out.. There's only one! I rekckon there should be one for each radiator but thought I'd check here first before making that assumption?
radiators..
- fatfreddy000
radiators..
“If all insects on Earth disappeared, within 50 years all life on Earth would end. If all human beings disappeared from the Earth, within 50 years all forms of life would flourish.” Biologist Jonas Salk
- KermitLeFrog
Re: radiators..
There is only one, on the right hand side. VTRs can run a bit hot around town but the single fan is very efficient and keeps things under control.
- fatfreddy000
Re: radiators..
Great news mate. That cheered me.KermitLeFrog wrote:There is only one, on the right hand side. VTRs can run a bit hot around town but the single fan is very efficient and keeps things under control.
I really don't need any additional expense and time spend on the beast right now.
I am waiting on a workshop manual to be delivered which will put a stop to some of my more simple questions..
Thanks..
- KermitLeFrog
Re: radiators..
I use a searchable pdf. You can download it from here:
http://www.corbridge-net.co.uk/VTR1000F ... al_OCR.pdf
Also, idle curiosity, that's the kit shown in your avatar?
- alanfjones1411
Re: radiators..
When i first got my vtr i was worried about overheating as in heavy traffic the fan kept on cutting in,but i was told by forum members it's natural and worry when it don't cut in.Two years later it still does it especially in hot weather.No worries.
- fatfreddy000
Re: radiators..
That the stator plate of a homebuilt 1 kW wind turbine being assembled.KermitLeFrog wrote:I use a searchable pdf. You can download it from here:
I will get a picture of the vtr up there when its in a better state..
Re: radiators..
If you find your bike overheats and the fan runs frequently you can put in a fan on the lh rad as well.
