Ohlins rear shock
Elchappo76
Re: Ohlins rear shock
Post by Elchappo76 »
lloydie wrote:
Elchappo76 wrote:Can i ask question here please.
Sent from my SM-G900I using Tapatalk
Depends on what sort or answer you want ?!
Thanks ...is it possible to rebuild top end whilst eng stil in frame.
Top end ! You mean heads ?
Or pistons ?
Elchappo76
Ahk ...motor got come out ...as have found front cyl spark plug has been bent by piston.
Check the piston too
Elchappo76
lloydie wrote:Check the piston too
Thank you ..will post pics of this build as i have not come cross bike eng with 103k on her clock ..but very well looked after so interested to see internal condition.
One of mine had 110k and used more oil than juice !
Elchappo76
lloydie wrote:One of mine had 110k and used more oil than juice !
Haha...this has not used a drop of oil ..since ive had last 8 mnths.. is down on compession.so im hoping can do whole eng on a $1000 budget
That's interesting.
Normally with high mileage engines the rings and bores are worn so they use oil.
If you have low compression with no oil use then I'd suspect guides or valve seats, so a simple heads off and refurb might be all you need.
