Ohlins rear shock
- carmanbikes
Ohlins rear shock
Hi, Would anyone have a picture of a Ohlins rear shock for the Firestorm off the bike, Thanks in advance
- StormyRob
Re: Ohlins rear shock
Found this.......
Sent from my E6653 using Tapatalk
- carmanbikes
Turn it round the other way so the bolt faces the opposite direction.
- carmanbikes
Hi, tried that and the remote canisters wouldn't go into the right place on the frame, but I think that is going to be the best way and get the canister and the remote swopped round, Thanks buddypopkat wrote:Turn it round the other way so the bolt faces the opposite direction.
- alanfjones1411
I have an Ohlins shock fitted to my bike. The canister is fitted to subframe L/H side and the remote is fitted to the subframe R/H side.
- carmanbikes
Hi, That is right but when I turn the shock around the canister will only fit on the right side with the remote adjuster on the same side, which looks to much on one sidealanfjones1411 wrote:I have an Ohlins shock fitted to my bike. The canister is fitted to subframe L/H side and the remote is fitted to the subframe R/H side.
Seeing as there's a short hose That could well be where it was made to go, Reservoir on the subframe and preload adjuster with the longer hose bolted to the pillion hanger.carmanbikes wrote:Hi, That is right but when I turn the shock around the canister will only fit on the right side with the remote adjuster on the same side, which looks to much on one sidealanfjones1411 wrote:I have an Ohlins shock fitted to my bike. The canister is fitted to subframe L/H side and the remote is fitted to the subframe R/H side.
- carmanbikes
Cheers, Will try it in the next few days
Some shocks are designed to run the remote on the right side of the bike.
The reason for this is that if you throw the chain, you will not damage the remote. It's a racing thing to limit damage.
On a street bike it is not that important which side it ends up on.
- bigtwinthing
8541Hawk wrote:Some shocks are designed to run the remote on the right side of the bike.
black round bits down are best!!!
- carmanbikes
Thanks for that Hawk8541Hawk wrote:Some shocks are designed to run the remote on the right side of the bike.
- Elchappo76
Can i ask question here please.
Sent from my SM-G900I using Tapatalk
Depends on what sort or answer you want ?!Elchappo76 wrote:Can i ask question here please.
