Clutch slave leak
- Pem Brooke
Clutch slave leak
Got a very slight weep on the first gasket of the clutch slave. Haven't pulled it apart yet...from what I can see on the service manual, the gasket (first one in, from the out side - left slide - of the slave) just needs replacing...
My logic is that if the piston seal was leaking, the leak would be from the drive sprocket side of the slave.
I'm sure lots of guys have pulled apart the slave previously...would I just need the gasket, or the whole repair kit?
Thoughts?
Thoughts?
Twist it 'til it breaks, then back off half a turn....
Clutch slave leak
If it's leaking it will be the piston seals .
As for The paper gasket , I don't even know why they fit it as it has no use .
The other little rubber seal is to stop crap getting on the piston .
So with all that in mind , if you have a leak it the piston seals that have gone .
Re: Clutch slave leak
Take it off and clean it out of gunk & grit that somehow gets into the clutch slave - Replace piston seal and check bore for scratches from aforementioned grit (lightly sand it down with wet+dry), rebuild with new gasket and bleed.
Or just transplant one in from a low milage Honda from around that period (Blackbird, VFR, CBR). About £15-£20 from fleabay.
http://www.ebay.co.uk/itm/HONDA-CBF1000 ... SwjVVVhY-o
http://www.ebay.co.uk/itm/HONDA-CBR1000 ... SwPcVVuAd6
http://www.ebay.co.uk/itm/2006-HONDA-CB ... Swqv9V5vxx
- Pem Brooke
Perfect! That's the advice and options I needed. Cheers for your help.
I'll have a check tomorrow but I may have one in stock...I'll get back to you on that one...Off tomorrow so will check in morn.
I definitely have one, PM'd to avoid selling in a non-items-for-sale section.
Probably cheaper than a seal kit.
Just as well as I didn't have one after all...tony.mon wrote:I definitely have one, PM'd to avoid selling in a non-items-for-sale section.
Isn't the one I'm selling the one I borrowed off you a while back, Mac?
Which reminds me- I still have your CDI and ECU units- never needed them after all- turns out that gas welding doesn't bugger the electrics if the battery isn't disconnected, after all....
I now have the original ones from the broken yellow Storm as well.
Thread hijack, apologies, nothing to do with leaking slaves, of any kind.
- bigtwinthing
off! Tomorrow! we will be overrun with bloody rats. Who authorised that!MacV2 wrote:I'll have a check tomorrow but I may have one in stock...I'll get back to you on that one...Off tomorrow so will check in morn.
'king Rat, probablybigtwinthing wrote:off! Tomorrow! we will be overrun with bloody rats. Who authorised that!MacV2 wrote:I'll have a check tomorrow but I may have one in stock...I'll get back to you on that one...Off tomorrow so will check in morn.
- bigtwinthing
tony.mon wrote:'king Rat, probablybigtwinthing wrote:off! Tomorrow! we will be overrun with bloody rats. Who authorised that!MacV2 wrote:I'll have a check tomorrow but I may have one in stock...I'll get back to you on that one...Off tomorrow so will check in morn.
I always liked Roland rat "heh heh Keveen"
My manager...As I was having a tooth out under IV sedation on the Monday & your not supposed to drive for 24hrs...I booked the Tuesday as a holiday but he told me as it was an 'operation' I got both days as sick...I was thinking of blowing out today but I'm a trooper & depist the pain I'm off to work shortly...there's Rodents to slaughter !bigtwinthing wrote:off! Tomorrow! we will be overrun with bloody rats. Who authorised that!MacV2 wrote:I'll have a check tomorrow but I may have one in stock...I'll get back to you on that one...Off tomorrow so will check in morn.
- bigtwinthing
is anybody else concerned about those "odd tasting bacon sarnies" at Macs on the "Grain all talk and bollox day? i am.
