Top Yoke
- carmanbikes
Top Yoke
Hi All, Dose anyone know if the black later type yoke will fit straight on the early model, It looks different where the key lock screws on, Thanks in advance
Re: Top Yoke
As far as I'm aware they are the same accept for the base where it sits over the bearing adjuster locknut rather than on top like the early models. The lock area should be the same as the only difference it that the Black plastic HISS shroud fits over the lock.
- agentpineapple
Re: Top Yoke
it'll fit mate, might be easier to just paint your existing yoke black tho, as carl said, you'll be left with the hiss mounting holes on show, of course you could get a hiss receiver for sub £20 and fit it in place, you can't connect it, but it'll look like you have it on your bike....
Re: Top Yoke
You could always wire the led to a switch so it looks like an alarm or HISS is fitted. Fake it, it works as well as any alarm.
