Ted's 'storm resto
Re: Ted's 'storm resto
Agree no Hydraulic tensioners on VTR's. That must some kine of generalised instructions. I don't know as I not read them.
I also agree, no hydraulic tensioners on the Firestorm,
Well, I've fitted them!! Took probably longer than 2.5 hours, but then I did have to clean all the years of cack off too!!
Will post pics when I have wifi and not 3G!!
- bigtwinthing
i turned mine over about 200 times before i pressed the start button, i was "cacking" myself. it started a treat, ran lovely and after 7000 miles haven't adjusted it once.Ted77 wrote:Well, I've fitted them!! Took probably longer than 2.5 hours, but then I did have to clean all the years of cack off too!!
Good job well done
It given you the chance to get in and do some more cleaning too.
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=25177
I did the carbs too, Carl - just forgot to say!! Also put new pads in the calipers.....just waiting for the new rear line to arrive so I can put them all on the bike and do the brake fluid/bleed!
- bigtwinthing
Great work Ted, like the red ones!
Is the Kitchen in the Garage or Garage in the Kitchen.
I see you have plastic end cap missing on the front faring bracket/stay. Check you still have the balance weights inside the tubes where the mirrors attach. They help reduce vibrations.
The garage has my sisters old kitchen units in it as my work bench!
And I just went and checked the bracket - both end caps are there ...just the photo makes it look like one is missing!!!
Work got in the way yesterday, but I have just ordered up a set of K-Tech springs to go in the front end when I change the seals/oil over!
Been busy cracking on, so not really been on here all that much.
Rear line fitted:
New springs, oil & seals done:
Old crappy springs:
Fairing bracket painted and back on:
Master cylinder bracket painted:
Fitting things back together:
And what she looks like now!
Just lower fairing to go on, and a bar end to get (if anyone has a spare + bolt, let me know!!) and then an MOT at the end of the week!!
Think it must be time for a beer!
Cheers for all your help
Rear line fitted:
Old crappy springs:
