Red storm dyno - hp on engine
Just post charts and set up details.
VT1000r
Re: Red storm dyno - hp on engine
Post by VT1000r »
8541Hawk wrote: Tue May 28, 2019 3:15 pm
VT1000r wrote: Tue May 28, 2019 8:19 am so my thinking is that ide open throttle no matter the rpm the slide is all the way up so how could needle tapper affect 5 to 7rpms or whatever if when you go full throttle the slide is in the same position throughout 1000 to 10000 rpms.
The bit you are not taking into account is that these are CV carbs. The slide is not connected to the throttle. The only thing you control with the throttle is the butterfly.
You can have the throttle wide open and the slide still be closed depending on operating conditions.
So when you go to full throttle the slide is not in the same position from 1000 to 10,000 RPM, in fact it is constantly moving.
One of the reasons tuning CV carbs cab be a bit tricky.
Oh ok I see now thanks for clearing that up for me it's had me confused for awhile.
