Rear shock spring Widths
Re: Rear shock spring Widths
That's guys that's some good info already :clap:
updated with ohlins
bigtwinthing
Post by bigtwinthing »
lloydie wrote:While ck and I are messing with the sssa ( single sided swing arm ) we have noticed a large size difference in the width of my white power shock spring and a standard shock spring .
So what I'm after is anyone with a aftermarket rear shock could you measure the width of shock spring please ?
I will keep updateing this first post as now measurements are post
I think it would be a good bit of info for anyone doing a conversion either exhaust or swing arm .
Thanks for your particapance :thumbup:
Standard ----- --80mm
White power--- 85mm
Hagon-----------73mm
Nitron------------85mm
Ohlins---==--- 83mm
Penske ------- --82mm
And any others
Bang on with the WP measurement, what side have you got your remote fitted too pls?
To the left .
I'm thinking about getting the hose changed to make it a better fit as no mAtter how you mount it the position don't seam right
bigtwinthing
lloydie wrote:To the left .
mines going on in march, iam looking forward to getting it fitted, any hints on the adjustment as i have no idea where the nuts need to be, iam 14 stone and like it "Firm" and i have been told 347mm ( i think)between bolt holes for the height!!!
