Engine cover bolt sizes and others
Re: Engine cover bolt sizes and others
carmanbikes wrote:This kit from bolt base on ebay 321235092423 what do you get in it, as I would like the sprocket cover and water pump, etc etc
Copy the bolts sizes from the list that you want and ask a seller to put it together for you .
In that listing you get
Water pump left and right engine casing sprocket cover and sump
Replacement bolts received :clap:
Thanks bolt base :-)
lloydie wrote:Replacement bolts received :clap:
Got mine today too,
Fantastic service :clap:
Mav617
Post by Mav617 »
And mine :thumbup:
gl_s_r wrote:
tony.mon wrote:Ah, but can they sell you the rectangular headed bolt to repair the starter motor lead mounting?
In Ti?
Drilled for lockwire?
Anodised Y124P Shining Pearl Yellow?
Delivered and fitted by an attractive young lady while I wait?
For under a pound, cash?
Can they?
Did you want one out of ti and cross drilled for wire?
no need to trouble yourself with that, mate.
I use some copper ones I found with a big head and file them to fit.
Greased properly and checked often they'll last a lifetime, and the weight saving will not be worth the effort of making them. But thanks for the offer.
mattycoops43
Post by mattycoops43 »
Does anyone know offhand what the front spindle clamp bolts are?
mattycoops43
Front axle clamp is M8 x 1.25 x 35mm 4off
mattycoops43 wrote:Front axle clamp is M8 x 1.25 x 35mm 4off
Added to the list thank you
darkember
Post by darkember »
LLoydie
The sprocket cover which includes the clutch slave cylinder should there not be 5 bolts, 3 for the slave & 2 for the cover itself. I atm only have 4 from your list??
Oh yes good spot :thumbup: what one is missing ?
mattycoops43
Just a heads up fellas.
I asked for a quote from several ebay sellers, they all came back to me with quotes around the £16 mark. But when I tried to follow up no one seemed like they wanted to bother listing it.
I went to my local bearing supplier to ask for a quote. They said it was cheaper to buy the bolts in 10s, so much that it worked out cheaper to buy even 10 of the one you need 1 of (85mm?) included. So I got about 100 bolts and 100 washers for £19 plus vat.
Did my bike, and now have tons of spares.
Just thought it's worth letting you know, most towns have a decent bearing/fastener supplier somewhere.
darkember
Post by darkember »
darkember wrote:LLoydie
The missing bolt is the one on the top just to the right of the slave cylinder its size is M6 / 50mm. Pity none of the ones I have left over are that length :(
Added to the list sorry
TheGingerBeardMan
Post by TheGingerBeardMan »
Received me bolts from Bolt-Base.
Working methodically, and taking me time from front to back, I come across the forks.
I've fitted the caliper body bolts and the fork pinch bolts. But, I noticed that there wasn't the 4 bolts that hold the caliper to the fork in the kit. :(
Checked the list, and they not there. Bugga. That'll be why they ain't in the order!
So....What size of bolts do I need to order to replace the ones that hold the caliper to the fork itself. 4 off. Cheers muchly! :thumbup:
TAX: 1st March 2017
MOT: 16th March 2017
INS: 14th March 2017
I'd leave them standard as their high tensile bolts ,
Wouldn't want them snapping on you would ya ?
