Engine cover bolt sizes and others
Re: Engine cover bolt sizes and others
Ah, but can they sell you the rectangular headed bolt to repair the starter motor lead mounting?
In Ti?
Drilled for lockwire?
Anodised Y124P Shining Pearl Yellow?
Delivered and fitted by an attractive young lady while I wait?
For under a pound, cash?
Can they?
I don't need one, you understand, it was just an enquiry.
I make mine out of old greenhouse bolts and grind bits off them until they fit, sort of.
I wonder what a full Ti kit would cost?
Indeed... At a guess, a small fortune.
carmanbikes
Post by carmanbikes »
I was gonna start taking bolts out and going to my local place but that's saved a load of messing that has,Thanks Very Much lloydie your a top fella :beer:
Mav617
Post by Mav617 »
Iain from Boltbase says if he gets the sizes for the fairing screws he'll do them also (flanged button heads for fairing, mudguard, huggers etc). I may get my rusty sh1t together and give him an order.
oorwullie43
Post by oorwullie43 »
Mav617 wrote:Iain from Boltbase says if he gets the sizes for the fairing screws he'll do them also (flanged button heads for fairing, mudguard, huggers etc). I may get my rusty sh1t together and give him an order.
That sounds like a plan! I need some of them! Let us know how you get on.
carmanbikes
Any one know what the head on the brake disk bolts are called I think they are 6m
carmanbikes wrote:Any one know what the head on the brake disk bolts are called I think they are 6m
Replace them with honda parts only .
And use thread lock . You don't want them snapping or coming loose do you !!!!!
carmanbikes
Ok Cheers
carmanbikes
Has anyone priced the full lot of the list up and not just the engine kit
Not me
gl_s_r
Post by gl_s_r »
tony.mon wrote:Ah, but can they sell you the rectangular headed bolt to repair the starter motor lead mounting?
In Ti?
Can they?
Did you want one out of ti and cross drilled for wire?
In Ti?
Can they?
how about in s/s ?
gl_s_r
Post by gl_s_r »
If you would like that, then I can do that for you.
I have ti brake disc bolts front and rear, they are button head bolts, can't remember the size of the top of my noggin tho..... :think:
carmanbikes
This kit from bolt base on ebay 321235092423 what do you get in it, as I would like the sprocket cover and water pump, etc etc
