How to balance your carbs
Re: How to balance your carbs
2600rpm in 5th or 6th is not something these big V2's like. it will be lumpy as hell if you try that, so it sounds like your bike is normal.
True dat luggin it at low revs in high gears will test the transmission. Use the gearbox supplied by Honda and if you really want to lug it along check the cush drive rubbers and chain tension are all tip top.
Bikermort
Post by Bikermort »
I rode my mates today and his is definately smoother. He noticed the roughness of mine too. Its not really bad but is enough to notice. Think compression test is next step.
Yamaha IT175
Honda CB900F 82
Yamaha YZ250 03
Yamaha XT600e 03
Honda VTR1000 03
NZSpokes
Post by NZSpokes »
Bikermort wrote:I rode my mates today and his is definately smoother. He noticed the roughness of mine too. Its not really bad but is enough to notice. Think compression test is next step.
Wont be compression. Whats your fuel screw setting? Any puss of black smoke? Whats your jetting? How is the air filter? Whats the output on your TPS?
Do the basics first.
And its not a car, give it some revs.
Bikermort
Post by Bikermort »
Im giving it some no worries there. You can feel it through the rev range. No smoke, air filter good. TPS havent checked that? I know what they do on fuel injection...not carby though? will have to look that up. Havent touched fuel screw settings. It doesnt feel like it bogs down at all and still make plenty of power just rough.
Starts easy enough every time so not thinking valves. Still think its some sort of balance problem be it carbs or compression?
Yamaha IT175
Honda CB900F 82
Yamaha YZ250 03
Yamaha XT600e 03
Honda VTR1000 03
AMCQ46 wrote:2600rpm in 5th or 6th is not something these big V2's like. it will be lumpy as hell if you try that, so it sounds like your bike is normal.
Agreed- what were you thinking?
You should be in 5K in fourth then, just picking up nicely.
Stir it up ((c) Bob Marley)
Bikermort
Post by Bikermort »
What was i thinking? I was thinking im riding to work and cruising at about 80km/hr.
Yamaha IT175
Honda CB900F 82
Yamaha YZ250 03
Yamaha XT600e 03
Honda VTR1000 03
NZSpokes
Post by NZSpokes »
Does sound like a TPS thing. Its on the RH side of your carbs. Plenty of how tos on adjusting it.
Bikermort
Post by Bikermort »
Thanks for that mate. Ill give it a go.
Yamaha IT175
Honda CB900F 82
Yamaha YZ250 03
Yamaha XT600e 03
Honda VTR1000 03
kenmoore
Post by kenmoore »
Check your TPS and do the Bernie Morgan air filter mod, that will help it smooth out.
South Coast
New South Wales
Australia
dudehog
Post by dudehog »
Hi, sorry to revive an old thread but I do have a question.
Reading the honda service manual it says the difference in vac between the front and rear is 0.8 inMg.
Now does this mean the front has a bigger pull than the rear or the other way around?
for example: (random vac numbers rounded to 1 inMg)
FRONT WITH A STRONGER VAC:
Front = -25 inMg
Rear = -24 inMg
OR
REAR WITH A STRONGER VAC:
Front = -25 inMg
Rear = -26 inMg
I'll be doing me first carb balance with this so want to get it right and this thread is far more helpful than the service manual so thank you :Beer1:
no its just setting it so the difference is no greater than 1
dudehog
Post by dudehog »
sweet. I'll try to get it as close to 0.5 inMg difference as possible. gives me a 0.3 tolerance :)
Bikermort
Post by Bikermort »
kenmoore wrote:Check your TPS and do the Bernie Morgan air filter mod, that will help it smooth out.
Adjusted my TPS today. I did it by just removing the seat and probing the wires at the ignition module. Was able to get at the TPS easy enough with the seat off too. It was at 758ohms. Have adjusted it to 500. Haven't gone for a ride yet only started it and it does seem to idle smoother. Riding into work in a couple of hours so will see how it goes.
And i did the airfilter mod too :D
Yamaha IT175
Honda CB900F 82
Yamaha YZ250 03
Yamaha XT600e 03
Honda VTR1000 03
Bikermort
Post by Bikermort »
TPS and air filter mod made a notable difference. Thanks to all those that provided useful advice!
Yamaha IT175
Honda CB900F 82
Yamaha YZ250 03
Yamaha XT600e 03
Honda VTR1000 03
