Front and rear pistons?
StormyRob
Re: Front and rear pistons?
Post by StormyRob »
freeridenick wrote: Thu Oct 05, 2017 10:17 pm Do you need a piston? I've got at least one you can have.
Yes mate. Front definitely. Will check rear tomorrow just to confirm mate
Red3446 wrote: Thu Oct 05, 2017 10:27 am As I supposed: piston pin offset is different (near to 1mm)
Piston one
Piston two
:thumbup: :thumbup: :wink:
As the others have said, many thanks for taking the time to do that and for supplying the photo's :thumbup:
Good question Rob, I wouldn't had thought there was a difference. I wonder if the JE high compression pistons are off-set the same :?:
Red3446
Post by Red3446 »
sirch345 wrote: Mon Oct 09, 2017 8:31 pm I wonder if the JE high compression pistons are off-set the same :?:
I Think so.
Consider that now, on modern engines (as for car as for motorcycle) manufacturers have two ways to reduce vibrations and friction: piston's pin offset or crankshaft offset (vs cylinder's axle).
Most used is pin's offset.
Red3446 wrote: Tue Oct 10, 2017 3:48 pm
I Think so.
Thanks for that information :thumbup:
Red3446
Post by Red3446 »
:thumbup: :thumbup: :thumbup: :thumbup:
sirch345 wrote: Wed Oct 11, 2017 12:01 pm
I Think so.
I've just had it confirmed that the JE pistons I'm going to fit can be used in either cylinder. That's direct from JE.
freeridenick wrote: Tue Dec 12, 2017 6:58 pm
I Think so.
That must mean the JE pistons are not off-set like the original ones are,
freeridenick wrote: Tue Dec 12, 2017 6:58 pm I've just had it confirmed that the JE pistons I'm going to fit can be used in either cylinder. That's direct from JE.
The Mori pistons are the same and also can be run in either cylinder
Though that doesn't mean they are not offset. :thumbup:
