Renthal Flat bar handlebar conversion.
Re: Renthal Flat bar handlebar conversion.
lloydie wrote: Wed Apr 25, 2018 8:35 pm Bike looks good :clap: them bars make it a much better road bike and for the aging rider :Beer Popcorn: :thumbup: :angel:
Thanks Lloydie :thumbup:
I have to agree on both points there :D
VTRDark wrote: Wed Apr 25, 2018 9:33 pm Hey Chris why can I see light through the front air vents. Are you missing some plastic from the inside of the fairings. Iv'e been eyeballing the 3" and 4" Apex Risers. They are seriousley teasing me but I'm going to hold off for now. Iv'e spent far too much already.
Those air vent plastics are designed by me to give less restriction :lol:
Only joking, they are standard, it must be the angle the photo was taken showing light through them like that. Trust you to spot that :lol:
Duffy1964 wrote: Wed Apr 25, 2018 11:49 pm Well done Chris Image
Thanks Duffy :thumbup:
I'm surprised it's almost 12mths ago I did this handlebar conversion :crazy:
Chrisd
Post by Chrisd »
Hi, Just fitted the high Rental bar conversion and had had to buy a remote res clutch due to the rise. It also mentions in the original post "fitting 3mm steering lock stops." Does anyone have any more information? How this was done ? any images? Thanks fellow Stormers.
There are several ways to fit lockstops.
You can simply araldite a 3mm packing piece onto the existing lockstops which you will find on the lower yoke.
A bit more professional would be to drill and tap, wind in a small bolt and grind the head down to the required thickness.
A permanent solution would be to grind off the lockstops, drill vertically and tap and fit cap head Allen screws instead in the required location, which is what I did.
bigtwinthing
Post by bigtwinthing »
I bought a Diaval instead ! so comfy.
Chrisd wrote: Sun Jun 03, 2018 11:36 am Hi, Just fitted the high Rental bar conversion and had had to buy a remote res clutch due to the rise. It also mentions in the original post "fitting 3mm steering lock stops." Does anyone have any more information? How this was done ? any images? Thanks fellow Stormers.
I've been meaning to add a couple of photo's, so I took some :)
I used a Contact Adhesive to fix the steering stops in place, I preferred that to Araldite as you don't need to secure the stops in place waiting for the glue to go off, although that side of it is up to you.
I fitted my stops when the fairing was off.
Out of interest how did you go about attaching a remote clutch reservoir :?:
Chrisd
Post by Chrisd »
Hi, thanks for guidance, done the stops people recommend. I have ordered a remote lever and master cylinder from a Bandit . Gives me options . Thanks
Chrisd wrote: Thu Jun 07, 2018 5:21 pm Hi, thanks for guidance, done the stops people recommend. I have ordered a remote lever and master cylinder from a Bandit . Gives me options . Thanks
Okay, thanks for your reply. You'll have to post up some photo's when you've finished your bar conversion,
Chrisd
Post by Chrisd »
All done, fitted bandit master cylinder instead of fixed Storm item.
good work ..... but now you need to sort the mirrors, as I bet you can only see your arms now
Chrisd wrote: Wed Jun 20, 2018 9:31 pm All done, fitted bandit master cylinder instead of fixed Storm item.BD4A878B-7B6A-4296-8172-DBC102580A82.jpeg
Nice work, well done :thumbup:
Do you mean you fitted Suzuki Bandit master cylinders (if so which Bandit) or is there a company who supply those parts with the name Bandit :?:
Chrisd
Post by Chrisd »
Hi, purchased some R6 Mirrors they work fine also the whole levers and master from a Bandit. Any will fit but I don’t think all had a clutch slave so as long as it does.... sorted
Chrisd wrote: Thu Jul 12, 2018 5:37 pm Hi, purchased some R6 Mirrors they work fine also the whole levers and master from a Bandit. Any will fit but I don’t think all had a clutch slave so as long as it does.... sorted
Thanks for the info on the levers and master cylinders, I've found them on Ebay now :thumbup:
Good to hear the R6 mirrors suit you,
PB05
Post by PB05 »
Where did you get your bar riser from for your conversion?
Thanks Brock.
PB05 wrote: Mon Jan 13, 2020 1:10 pm Where did you get your bar riser from for your conversion?
Thanks Brock.
I have searched my back-ups and found the pic's which I have now re-attached in my post on page (1) for you and anyone else who might be glad to see them :thumbup:
I have written in that post where I found my bar risers:-
viewtopic.php?f=31&t=41099&p=447010#p447010
HTH's,
PS. Welcome aboard :thumbup:
Rhughes945
Post by Rhughes945 »
Well, your post and pics (probably the red bike is doing it for me) has inspired me.
Thinking I might take the plunge and buy one of these
https://www.ebay.co.uk/itm/Abm-Superbik ... 4137862114
Anything I need to watch out for? Can get spacers from work to bring the steering stoppers in, but I'm still unsure about location of the clutch and brake reservoirs.
Is it possible to get remote ones? Or extend them inwards somewhat?
