VTR-engined / buggy Crosskart
if this is ok, I´ll make a thread about the build !
The chassies was located in the addic of a friends dads truckingcompany, it had been sitting there since new, 1992 - never used.
Engine was given to me for free as a friend crashed his bike with no Insurance.
So the choise was kinda easy !
My local motorcycle breakes has had a super discount offer, since August last year. with such low prices that it seems to be free.
brakecalipers 8 Pounds, shocks 8 Pounds, fueltanks 8 Pounds, rectifier 5 Pounds, frames 20 Pounds, etc etc
So i have been there about 50 times in the last 6 months hoardning parts :-)
- Attachments
- 17349866_10154349122979080_6479932739969264809_o.jpg (225.41 KiB) Viewed 5370 times
- 15400493_10154070831019080_6445136011352459085_n.jpg (205.44 KiB) Viewed 5370 times
- 15355578_10154070830624080_4806266120889244081_n.jpg (187.97 KiB) Viewed 5370 times
- 15127302_1015401356kk.jpg (269.91 KiB) Viewed 5370 times
- 15039584_10154011388189080_6463542371904138710_o.jpg (435.28 KiB) Viewed 5370 times
Re: VTR-engined / buggy Crosskart
Is that a Varadero engine?
tony.mon wrote:Is that a Varadero engine?
Hi Tony. nope, its an -98 VTR in a Varadero frame.
Im not the best of welders, so i tend to weld a bit too much, so i have grinded down all welds a Little to make them look nicer, not the very best idea i know though :-)
- Attachments
- 20170411_195142.jpg (1.1 MiB) Viewed 5319 times
- 20170411_195136.jpg (1.16 MiB) Viewed 5319 times
- 20170409_183010.jpg (1.9 MiB) Viewed 5319 times
- 20170408_185638.jpg (343.21 KiB) Viewed 5319 times
- 20170408_185624.jpg (1.26 MiB) Viewed 5319 times
- 20170408_185534.jpg (325.58 KiB) Viewed 5319 times
- 20170331_160959.jpg (1.07 MiB) Viewed 5319 times
- 20170328_170322.jpg (1.19 MiB) Viewed 5319 times
gear-lever is of an CBR600. also i have lengthened the "lever" a Little & attached a plastic knob on it.
Hydraulic handbrake is the extra handle from my anglegrinder, attached to a CBR1100XX rear brake cylinder to a Kawazaki ZX9-R front brake 6-pot on the rear axle.
- Attachments
- 20170416_211549.jpg (1.15 MiB) Viewed 5319 times
- 20170415_000912.jpg (343.06 KiB) Viewed 5319 times
3mm lexan sheets are covering the frame.
- Attachments
- 20170504_201133.jpg (243.72 KiB) Viewed 5318 times
- 20170430_230624.jpg (1014.98 KiB) Viewed 5318 times
The Wheels front are 12" Nissan Micra 1986 :-) 4x100, brakediscs are VW Polo/Audi 80, -83, machined down 25mm,
brake calipers front are Yamaha R1 -13, which have had the bleeder-screw remowed and welded shut
- Attachments
- 20170511_191747.jpg (1.16 MiB) Viewed 5316 times
Last edited by Kristian Hesselmark on Tue Jun 13, 2017 9:31 pm, edited 1 time in total.
Coolant expansion bottle is from an Yamaha TZR125,
also the entire electrical system has been "cut" down to fit as nicely as possible
tires front are from a moped, in 120/70-12 two different sets, the nearest "street-usable" pictured.
Low beam is Twin small LED 24W, high beam is a LED bar on top of the rollcage, about 120W
CBR600 ignitionkey,
Honda S2000 Copy starterbutton
pitbike killswitch
Swithes are for the lights and the Ducati 996 fan :-)
Electronic ebay revcounter with hourmeter
The radiator is an Yamaha FZR1000 -89
CBR600 ignitionkey,
pitbike killswitch
- Attachments
- 20170523_201553.jpg (1.23 MiB) Viewed 5315 times
- 20170520_213853.jpg (222.79 KiB) Viewed 5315 times
- 20170520_213845.jpg (195.39 KiB) Viewed 5315 times
- 20170520_213807.jpg (211.69 KiB) Viewed 5315 times
- 20170520_212137.jpg (244.26 KiB) Viewed 5315 times
- 20170512_231555.jpg (1.1 MiB) Viewed 5315 times
- 20170512_231548.jpg (1.13 MiB) Viewed 5315 times
quite proud of my homemade fitting for the chocke-lever too, works perfectly
- Attachments
- 20170523_201614.jpg (218.57 KiB) Viewed 5314 times
- 20170523_201606.jpg (197.77 KiB) Viewed 5314 times
Wing is a "styling" wing from a car, cut down 20cm, as it was way to wide.
look closely and you will see 5 rear lights. the 2 black ones are parkinglights (Always on). and the Three others are brakelights , all LEDs
- Attachments
- 20170526_181412.jpg (346.13 KiB) Viewed 5314 times
- 20170526_181239.jpg (323.14 KiB) Viewed 5314 times
- 20170526_181230.jpg (368.33 KiB) Viewed 5314 times
- 20170526_173001.jpg (334.48 KiB) Viewed 5314 times
- 20170523_201740.jpg (1.25 MiB) Viewed 5314 times
- 20170523_201732.jpg (258.31 KiB) Viewed 5314 times
- alanfjones1411
That is one mad machine.
- KermitLeFrog
Mega!
Ah, it was the centrestand that got me thinking.Kristian Hesselmark wrote:tony.mon wrote:Is that a Varadero engine?
Video´s loading om YOUTUBE : https://www.youtube.com/channel/UCFize5 ... eeds0ujCPw
