Page 10 of 46
Posted: Fri Dec 01, 2017 2:36 pm
by Varastorm
Thanks Chris, bit slow in actual building at the moment though.
Same thing went on last year, all the major thinking for the flat tracker went on about now. It's a cracking time to get things I really want instead of the usual crap/presents, jumper, socks I really need
I've been busy searching things I'll need & I'm happy with the bits I've bought.
But, I didn't really think about the header manifolds. I feel that after all this stainless pipework faf, I can't really have oem mild steel flanges
So I've been looking into what would be needed to make some nice looking header flanges. The items I've seen & want to copy are from a recently sold on eBay rc51 exhaust.
They are similar in design to the titanium Arrow Cbr600 set up I have & looks so god dam good with all those springs.
This is what I'm thinking of.
Buying a short 300mm length of Stainless bar 65mm wide 8-10mm thick to make the flanges (The oem Vtr items are 62mm wide flanges).
Buying/making some 3mm wall 51mm od pipe & cutting 2 pieces to 20mm lengths. These will be welded to the engine side of the flanges.
Then buy/make some 1.5mm'ish walled 45mm id pipe to be welded to the outer side of the flanges. These will be used as stubbs for the header pipes to locate in. Hopefully these will assist with the on & off setting up the exhaust when it's been fabricated.
I feel It's safe to say this exhaust faf is snowballing out of control
Posted: Sat Dec 02, 2017 11:10 am
by fabiostar
snowballing? you mean snow balled way outa control
but thats what winter is for......carry on il get my coffee here.....
Posted: Sat Dec 02, 2017 12:08 pm
by Varastorm
fabiostar wrote: ↑Sat Dec 02, 2017 11:10 am
snowballing? you mean snow balled way outa control ..
I know Fab, bit embarrassing really but hey ho, I mean ho ho ho..
Anyhoo, more bits arrived on the post mans sleigh today.
The 1250mm length of stainless arrived, I was a bit worried the tube & bend diameters would be different.
Some sell their product in Metric & some sell in Imperial. They both state 45mm & with both countries (China/UK) using the metric system, I was surprised to find they are actually 1.750".
So long as they're both the same it'll look okay, it's just the id of the link pipe/header pipe bits I need to be a good fit.
Posted: Tue Dec 05, 2017 1:27 pm
by Varastorm
Posted: Tue Dec 05, 2017 3:31 pm
by Varastorm
Since buying the silencers, I've been looking at lots of SC Project exhausts & I've noticed that if it wasn't for the huge diameter link pipe to the silencer (if you can call it that) it would look even sillier.
This has made me think about the link pipe diameter & the diameter choices that the exhaust link pipes offer.
I'll quickly add that I've just ordered a small 500mm length of 48mm stainless pipe for joining things together & for sliding 45mm inside.
This 48mm pipe should also allow my "leftover inlet" 1.5mm walled 51mm pipe to slide nicely over that. So if it fits & looks okay I could "megaphone" from 45mm to 48mm to 51mm then into the silencers.
Or should I go straight into the silencers with 45mm?
What do you recon ?
Posted: Wed Dec 06, 2017 7:32 am
by lloydie
Taper it it’ll look much better
Posted: Wed Dec 06, 2017 3:29 pm
by Varastorm
lloydie wrote: ↑Wed Dec 06, 2017 7:32 am
It won't be a nice funnel taper though Lloydie, hopefully it will look nice but more of a stepped taper.
In hindsight, It would of been better to make the whole thing out of 48mm pipe. 45mm manifolds out of the heads, then the rest 48mm up until the final run to the silencer's then a 51mm step. The cost would of been huge though, as I can't find cheap 48mm Chinese mandrel bends.
Btw, when I say cheap I don't mean quality. The finish of the Chinese sanitary piece's is far superior to the pipe I'm buying from the UK.
Anyhoo, the postman's sleigh arrived at mine again today..
The 500mm length of 48mm diameter pipe arrived, same as before I had to open & check it
Eger to see if the idea of slip fitting 3 different diameters would work, I popped to the shed & cleaned the ends up to see.
Initially the 48mm wouldn't slide over the 45mm piece, bugger. Then I decided to flip ends with the 48mm.
Perfect, slid in so nicely
One end of the 48mm did have a dink/flat but that's no big issue because it will force on by hand for a weld joint.
The slip fit is as good, if not the same as the Cbr600 Arrow setup I have.
I'm made up tbh, If it works for them..
Next on the to do list is find quality cheap stainless exhaust springs & then fabricate some spring hoops out of 1mm tig rod wire bent over a 6" nail. It's coming together slowly
Good job I checked the pipe though, otherwise Christmas could of been wrecked
Posted: Wed Dec 06, 2017 3:58 pm
by sirch345
Apparently Santa had to make an extra trip especially for you, all because of the extra weight he was not expecting to be carrying
I luv the look of the end can's, an amazing price.
I won't mention anything to your wife..........................................................MRS VARA are you there
Posted: Wed Dec 06, 2017 4:43 pm
by Varastorm
sirch345 wrote: ↑Wed Dec 06, 2017 3:58 pm
Just had a text from Santa
about a 52mm pipe upgrade for Rudolph
Posted: Wed Dec 06, 2017 9:46 pm
by fabiostar
Posted: Wed Dec 06, 2017 10:26 pm
by Varastorm
It's going to be interesting to hear them Fabio, could be good, could be bad.
Just wish Kenmoore would get a sound clip of his setup up.
It's getting expensive too, especially with Christmas only 19 days away
Posted: Thu Dec 07, 2017 8:19 am
by fabiostar
Varastorm wrote: ↑Wed Dec 06, 2017 10:26 pm
lets just hope santa is good this year
Posted: Thu Dec 07, 2017 12:34 pm
by Varastorm
The sleigh pulled up yet again today, I was out front sweeping carrot remains from yesterdays visit..
Here's today's goodies, all £16.58p of them. had to have a look-see to check all's good. Just in case Christmas gets ruined
Same idea as the inlet manifold, they'll be drilled with 10mm holes to gain access to the butt jointed tubes & then tack welded together
Posted: Thu Dec 07, 2017 1:21 pm
by Varastorm
Just ordered some of these.
Motorcycle Exhaust Mounting Springs Fully Rotatable 64MM Stainless Steel.
Had a check & they're the same size as the ones that came with the silencers.
Bit shocked with the amount though, 10 packs of 4.. Time for a chat in the mirror me thinks
40 springs, £15.56p delivered.
Watch out Akrapovic, here I come
Posted: Thu Dec 07, 2017 2:05 pm
by sirch345
Varastorm wrote: ↑Wed Dec 06, 2017 4:43 pm
Ooooooo that sounds painful
It's surprising what you need to build this exhaust system.
I can now see how the cost rockets up,
