New to the forum
Re: New to the forum
You can fit a new ceramic bearing but it's really only needed if it starts leaking psst the seal.
And they're not cheap....
There's a small drain hole just forward of the water pump with either just a plain hole or a 90degrees spigot.
If the water level drops then it's worth looking into, not otherwise.
allanparanihi
Post by allanparanihi »
tony.mon wrote: Sun Nov 26, 2017 8:50 pm You can fit a new ceramic bearing but it's really only needed if it starts leaking psst the seal.
Gotha
