PMs stuck in outbox
PMs stuck in outbox
anyone else have problems with PMs getting stuck in outbox?
Re: PMs stuck in outbox
Other people will correct me if I am wrong, but as I understand it the PM stays in the outbox until and if it is read.
PM's only disappear from the outbox when the recipient opens your sent message,
Some of us been at work all day & oly recently opened them...
ah, that explains it! a couple of stuck ones are for yeti but he's not on here so much. thanks for that. just added confirmation that i actually am as thick as i look...
At least you now know what was happening, or in your case not happeninghaynesjones66 wrote: ↑Fri Oct 16, 2020 6:26 pm ah, that explains it! a couple of stuck ones are for yeti but he's not on here so much. thanks for that. just added confirmation that i actually am as thick as i look...
You don't need to run yourself down, there is enough on here to do that for you
I've just msg'd him via F/B again for you, hopefully he will open up his PM's...haynesjones66 wrote: ↑Fri Oct 16, 2020 6:26 pm ah, that explains it! a couple of stuck ones are for yeti but he's not on here so much. thanks for that. just added confirmation that i actually am as thick as i look...
thanks mate
