Tick Tock
Chrisd
Tick Tock
Post by Chrisd »
Hi All, Question time!!! Have anyone had any issues with a tinny tapping sound at low revs and slight throttle. I does reduce when you pull the clutch in but is still there. At higher revs it seems to decrease or I just I can't hear it. It is not the MCCT's. Could it be something in the carb rattling on lower revs seems to go about 3500? Thanks
Re: Tick Tock
Airleak from exhaust manifold or link pipes ? Something loose on the bike and resonating? Cup the exhausts and have a listen around.
Re: Tick Tock
Chrisd wrote: Wed Jun 20, 2018 9:26 pm Hi All, Question time!!! Have anyone had any issues with a tinny tapping sound at low revs and slight throttle. I does reduce when you pull the clutch in but is still there. At higher revs it seems to decrease or I just I can't hear it. It is not the MCCT's. Could it be something in the carb rattling on lower revs seems to go about 3500? Thanks
ahh i was just chatting to you on facecake about this lol :thumbup: :thumbup:
Chrisd
Re: Tick Tock
Post by Chrisd »
Going to try the easy bits before entering the clutch. Air leaks and Balancing the carbs.
Cheers lads. :clap:
