Changing from clip ons to normal bars?
I think I have to accept Im not as young as I was. I love my Hawk to bits but it kills me to ride it. My legs and hip scream after a long ride.
So much so Ive been avoiding riding it and been riding my 1200 Bandit which is boring as butter but I can ride it all day in comfort.
I dont want to sell the Hawk so am thinking among other things fitting normal bars.
What are the difficulties in doing this? I have a top clamp with mounts. Are the cables and lines long enough?
- bigtwinthing
Re: Changing from clip ons to normal bars?
Hi
I have a CNC topyoke and Renthals fitted, They are superb. However i fitted new hoses and trimmed the fairing very slightly. Well worth the mod though.I rode for 560 miles in a day last year and they were great . I have pics if you need any. i aint young either!
- bigtwinthing
- bigtwinthing
Done mine too about 2 years back and never looked back. You will be better off with new brake and clutch lines that are longer as it will give you the slack to play with.
Cheersbigtwinthing wrote:Here we are.
Did you need to trim for the bottles to clear?
My brake lines are off a 900 Hornet so to long for the Hawk anyway. So the electrics were ok?darkember wrote:Done mine too about 2 years back and never looked back. You will be better off with new brake and clutch lines that are longer as it will give you the slack to play with.
The bottles will clear it was the switch gear that needed to be trimmed for.
No need to change any of the wiring to the switches and the throttles cables just needed re routing
I had to add 2" to the horn wiring but the aftermarket good ridge hoses that I had on it were ling enough.
How did you trim the fairing?bigtwinthing wrote:Hi
Did that include the clutch line?AMCQ46 wrote:I had to add 2" to the horn wiring but the aftermarket good ridge hoses that I had on it were ling enough.
just trim the fairing with a dremil or the like. you can fit either low risers or high riser bars, obviously high risers require more trimming. some have changed resivours to keep them lower also.
standard length hoses fit for break and clutch. horn wires were all I had to extend.
Don't hassle me
I'll get there at some time
This dude doesn't value his life too much or the guy who wins these.
Death trap jumps to mind. eBay item number: 251935806735
