Page 1229 of 1496
Posted: Thu Nov 08, 2018 11:03 am
by Commando77
Finally separated the frame from the engine.... Not easy solo withe the rear mount bosses fouling nearly everywhere and a part seized front stud(rg part)
. Now debating if its worth splitting the cases as the mainshaft brg feel good with clutch off. Still it was always worse hot and since I've got this far...
Posted: Thu Nov 08, 2018 4:16 pm
by MacV2
Rode it...
Went over the Nam to see Vanhobble...
Still getting to kill a few flying bugs on the way home...
Posted: Thu Nov 08, 2018 6:18 pm
by chromedome
Fitted a 'new' starter motor. Having noticed my 'Storm was struggling to start, despite a new MOSFET R/R and a healthy battery, I took a peek under the rubber boot of the starter motor - oh dear! Thanks to the very helpful thread on this forum, I ordered a Blackbird starter from ebay for under £40 delivered, and she now starts first press of the button! VTRs aren't kind to starter motors!
Posted: Sat Nov 10, 2018 6:09 pm
by freeridenick
Started stripping it down for the frame swap.
Posted: Sun Nov 11, 2018 12:24 am
by tony.mon
Fitted more Titanium bolts to the front caliper mounts, that's all of them now.
Posted: Tue Nov 13, 2018 11:42 pm
by Wicky
Cleaned my bike and slapped on winter coating of ACF-50
Posted: Thu Nov 15, 2018 9:23 pm
by Commando77
Finally got he flywheel off and split the cases. Missed the bolt above the clutch inside the case
Pulled the gear clusters and confirmed the main shaft get is knackered....thought I was going mad when it felt ok. Cleaned in petrol and spun up it has masses of end play and a nasty little rough spot. 1st gear has a sloppy needle race....don't know if that's normal?
Mains look pretty good, little wear so I'm leaving them. Will check the rod brgs but expecting them to be ok. Will change those anyway.
Posted: Thu Nov 15, 2018 9:36 pm
by sirch345
Commando77 wrote: ↑Thu Nov 15, 2018 9:23 pm
Good news on the main shaft bearing, at least it was as you thought all along, seen better days,
Posted: Fri Nov 16, 2018 8:18 am
by tony.mon
That little bolt got me, too, the first time I split one.
You're not alone....
Posted: Fri Nov 16, 2018 4:35 pm
by freeridenick
The same bolt got me too.
Don't forget new rod bolts when you check the bearings. Use the old one to check and the replace with new.
Posted: Sat Nov 17, 2018 4:39 pm
by sirch345
I'm guessing this bolt I've ringed in red is the little blighter
Posted: Sat Nov 17, 2018 4:42 pm
by freeridenick
That one and the one behind it are the two reasons you can't split the cases without taking the heads off.
Posted: Sat Nov 17, 2018 5:03 pm
by sirch345
freeridenick wrote: ↑Sat Nov 17, 2018 4:42 pm
Handy to know, cheers Nick,
Posted: Sat Nov 17, 2018 5:15 pm
by freeridenick
sirch345 wrote: ↑Sat Nov 17, 2018 5:03 pm
The one on the inside will come out but the one on the outside won't, but then you can't torque them up.
Posted: Sat Nov 17, 2018 10:04 pm
by Commando77
I see what you mean but any of those bolts can be torqued with a ring spanner and a spring balance. I wonder what Honda did? The outside bolt you talk about undoes ok but stays in place. Are you saying it won't release the bottom end because it fouls on the head?
