Calipers
Best deals in town
carmanbikes
Calipers
Post by carmanbikes »
Just got these back from Jay at Chameleon anodising very happy with both the finish and the fast service
Re: Calipers
Glad you're happy with them mate, top service from Jay innit? :clap:
Now buy some nice Ti/stainless bolts to clean them up :thumbup:
carmanbikes
Re: Calipers
Kev L wrote:Glad you're happy with them mate, top service from Jay innit? :clap:
Hiya Kev, yes really happy with them, been on net all night looking for some s/s bolts and pins I think the best ones are Pro-Bolt but not a lot on there site so I have sent them an email for a price :thumbup:
bigtwinthing
Re: Calipers
Post by bigtwinthing »
S/S isn't a high tensile material. i wouldn't use them on Brakes or Suspension. They also have an adverse effect with some Alloys.
Re: Calipers
Have a look at Titanclassics for Ti, cheaper on his website than e bay. Powerhouse are very good for bolts as well.
carmanbikes
Re: Calipers
bigtwinthing wrote:S/S isn't a high tensile material. i wouldn't use them on Brakes or Suspension. They also have an adverse effect with some Alloys.
I hadn't realised that, The only reason for changing them is for appearance so I will have to go the more expensive ti, Thanks for the info :thumbup:
Re: Calipers
True. However the stresses acting on these bolts are such that the bolts locate the two parts together, the act of applying the brakes tries to move one part (the caliper) forward relative to the fork leg mount. Therefore the bolt strength required is shear strength and not tensile strength. The force acts across the bolt diameter, sideways on, if you like, and not a pull along the axis of the bolt.
I'd be very surprised if there was sufficient force to shear through two 6mm bolts, let alone the two M8 ones fitted, in stainless or high-tensile steel.
Our engineers will have values on this.
However, I can only say what I'd be content to ride with, you will have to make your own choices- it's your neck!
bigtwinthing
Re: Calipers
i agree Tony but bit too late to say i told you so as you fly over the bars. I personally would not take the risk. Just buy Ti ones. theres only 4 isn't there.
carmanbikes
Re: Calipers
I am replacing the bolts that hold the callipers together as well :thumbup:
Re: Calipers
carmanbikes wrote:
bigtwinthing wrote:
tony.mon wrote: True. However the stresses acting on these bolts are such that the bolts locate the two parts together, the act of applying the brakes tries to move one part (the caliper) forward relative to the fork leg mount. Therefore the bolt strength required is shear strength and not tensile strength. The force acts across the bolt diameter, sideways on, if you like, and not a pull along the axis of the bolt.
Now THOSE bolts need to be high tensile.
Stephan
Re: Calipers
Post by Stephan »
Oem caliper bolts are s/s, disc bolts and triple tree bolts too. You just need to choose correct bolts suitable for application (or oem). But is is the same with Ti.
I use s/s high tensile bolts grade 10.8 on calipers for years.
