blackstorms handling woes
Test your messages here, beginners welcome..
struv112
Post by struv112 »
andy c your problem with your forks is because you havent been on ebay and bought yourself a set of pre 97 fireblade forks and bunged them on i find they work much better white power rear shock l help too :D
andy c
handling woes
Post by andy c »
thanks for your input what else do you need apart from forks and do they bolt straight in ? and how much £
andy
Stormtrooper
Post by Stormtrooper »
you can get the front end sorted by rodger at revolution racing for £199
struv112
Post by struv112 »
hi andy the bike was already modded when i bought it but as far as i can see i have pre 97 fork legs and yolks and front mudguard 'callipers handlebars mounted below top yolk i presume are allso blade the rest looks like its all firestorm what i can say though is i havent ridden a standard storm but i have no problems with the front end handeling as for cost from a breakers prob a couple of hundred for the bits probably half that on the ebay hope i have helped
