Manual Gear-change indicator
Test your messages here, beginners welcome..
budd
Re: Manual Gear-change indicator
Post by budd »
simo wrote:Managed to get this fitted, made easier with having Pyramid lower fairing mountings/brackets to mount contacts
Image[/url
[URL=http://s1241.photobucket.com/user/jackjoe12/media/Mobile%20Uploads/2014-03/460A8226-C816-41AB-8C10-C85EFED304FD.jpg.html]Image
where did you connect it to the neutral switch?
Storm is now gone :cry: .
That does look like a complicated way of doing it.
I use a combined gear indicator/voltage display unit, can't say it's better, but it's a bloody sight easier to fit.
I posted a how-to in the workshop knowledgebase years ago.
simo
Post by simo »
Image[/url
where did you connect it to the neutral switch?[/quote. No it's a wire which you get need connecting to the bikes nutral, I soldered it to the original connector.
Theres A Hare in The Turnips.
budd
Post by budd »
simo wrote: No it's a wire which you get need connecting to the bikes nutral, I soldered it to the original connector.
you connect the white wire from the unit to neutral, yes? where exactly did you splice in the wire? is the connector in the loom? at the switch isteslf or is it possible to use the neutral light feed ?
simo
Post by simo »
I extended all the wires by soldering using proper wire, not that thin stuff. Cut the cover off the connector that pushes on the neutral switch, prise the lugs open on the terminal and solder to that , close it back up with plyers and heat shrink a few inches back. Yes I think it was a white wire.
budd
Post by budd »
simo wrote: I extended all the wires by soldering using proper wire, not that thin stuff. Cut the cover off the connector that pushes on the neutral switch, prise the lugs open on the terminal and solder to that , close it back up with plyers and heat shrink a few inches back. Yes I think it was a white wire.
thanks for that BTW where is the neutral switch? :D
simo
Post by simo »
You can see a wire in the picture heading that way, just near/behind the gear selector lever.
budd
Post by budd »
simo wrote:You can see a wire in the picture heading that way, just near/behind the gear selector lever.
Cheers I'll have look :thumbup:
Are you going to get one of these kits then Budd. I must admit I'm quite tempted myself for that price. Simo do you think it would be easy to remove the casing on the gear indicator leaving only the circuit board for installation inside the instrument panel/clock face. :think: Are there any screws holding the case on or is it a sealed unit?
simo
Post by simo »
cybercarl wrote:Are you going to get one of these kits then Budd. I must admit I'm quite tempted myself for that price. Simo do you think it would be easy to remove the casing on the gear indicator leaving only the circuit board for installation inside the instrument panel/clock face. :think: Are there any screws holding the case on or is it a sealed unit?
Yes Carl that might be possible. Good idea.
Virt
Post by Virt »
How much extra wire did you have for the display? I quite fancy one for that price, but I'd rather stick it on the right of the bike as I have the late model clocks
simo
Post by simo »
Yes you could do that, there's enough wire for that but some might have to be extended as I did. Eg. Power and earth.
budd
Post by budd »
yeah I think I will, at the very least it will stop me trying to change into 7th :D
I have an Acumen fitted, it's like Tony's but without the volt meter incorporated in it. Easier to fit than yours Simo, but costs a lot more. You can't complain about the price of yours :thumbup: and ideal for anyone who is a bit handy when it comes to the bike,
simo
Post by simo »
sirch345 wrote:I have an Acumen fitted, it's like Tony's but without the volt meter incorporated in it. Easier to fit than yours Simo, but costs a lot more. You can't complain about the price of yours :thumbup: and ideal for anyone who is a bit handy when it comes to the bike,
Aye well I would have liked one of those but as I understood it I would have had to splice into the ECU harness,a newer bike you buy a harness so it just plug in??? Don't know if the last of the Firestorms would qualify. ?
