Thought I would try here as well
My n7100 is stock
I received an update notification from samsung a few weeks ago, so I installed 4.4.2
Since then I have been unable to connect via mobile data
I can turn it on but there's no connection
WiFi is ok
I have used the sim (virgin UK) in a different phone and it works
I have done a factory reset today bit still have no data connection
Any help you can give would be much appreciated
Galaxy Note II. No mobile data connection after 4.4.2 update
Re: Galaxy Note II. No mobile data connection after 4.4.2 up
I had the same with my galaxy s5 turned out to be an update that killed the "mother board" thing inside the phone .
I was sent a new handset
- Miztaziggy
Definitely no issue with 4.4.2 as I have it on my S3 and Sarah on her Galaxy Note 2 and also her HTC M8. All work fine.
Bring it round I will see if I can fix it.
